Breguet balance for Thos Russell?
Vintage Pocket Watch Discussion Forum
Barryw1957
#1 Post by Barryw1957 » Thu Aug 10, 2017 7:47 am
Hi all,
I have a Thos Russell half hunter pocket watch that is need of repair. I have been informed by a specialist antique pocket watch repairer that it needs a replacement Breguet balance, which I am led to believe is very scarce....he doesn't have one! The watch movement is 36mm dia slim movement and has a personal inscription with the date of 1923. If anyone is able to help or offer advise I would very much appreciate it. From what I have been told, the existing movement shows a previous attempt to clean it with oil and the balance is now stuck even after being soaked in solution to free it. I assume that the experts among you will recognise the folly in using non-specialist oil and will also know of the solution used, to attempt the clean.
This is a family heirloom so any help would be greatly appreciated.
Regards
Barry
JerryT
Re: Breguet balance for Thos Russell?
#2 Post by JerryT » Fri Aug 11, 2017 11:19 pm
Can you show us a picture of the watch mechanism ("the movement")? It is rare that an entire balance wheel assembly needs to be replaced on a pocket watch unless it has really seen some abuse.
Barryw1957
#3 Post by Barryw1957 » Mon Aug 14, 2017 10:13 am
Many thanks for the speedy reply (JerryT), I really appreciate it. If I have done this correctly, you should be able to see the movement from the following link. All I can tell you is that when the spring was removed it was soaked in a solution or 10 minutes but I was told that it was still "stuck together" and couldn't be freed. The whole movement was also "full of oil" to coin his phrase. I was told that the only chance I had was if someone had a movement from the same type of watch, from the same date range (early 1920's) ...the chances of which are very slim.
I still hope someone can help :)
http://s1262.photobucket.com/user/Barry ... g.html?o=0
Thanks again,
Barry
Barryw1957
#4 Post by Barryw1957 » Mon Aug 14, 2017 2:40 pm
I have been told that the link to photobucket doesn't open the images so please try this one.
https://www.flickr.com/photos/151632655@N08/
Many thanks
Barry
JerryT
#5 Post by JerryT » Mon Aug 14, 2017 10:03 pm
From your photo the watch does not look that gummy and it is hard to believe that the entire balance wheel needs to be replaced. I might try consulting a different watchmaker.
Barryw1957
#6 Post by Barryw1957 » Tue Aug 15, 2017 12:37 pm
Thanks for that JerryT. I live in the North West (Bolton), is there anyone you can suggest that may be able to help me? I do mean with the watch by the way...I am beyond help for living in Bolton :lol:
JerryT
#7 Post by JerryT » Wed Aug 16, 2017 12:26 am
Since I live in the States I am afraid I cannot help you on qualified watchmakers near you. I am glad to see, though, that you have connected with some more knowledgable NAWCC members who do live in England.
Barryw1957
#8 Post by Barryw1957 » Wed Aug 16, 2017 9:07 am
I appreciate your help Jerry
